Saxosim Posted July 25, 2017 Share Posted July 25, 2017 Hi All I have a set of brand new 165mm JVC Speakers sat doing nothing that I would like to fit into my wife's Streetka to replace the current stock door Speakers. Can anyone tell me which adapter ring brackets I would need to fit them as I am looking at mk1 ford ka adapters as I assume they are the same Speakers in a streetka and a ka but there seems to be some variation in brackets available. I am pretty sure the standard streetka speakers are 5x7's. Are the interior door panels the pop off type too on a streetka? Any help from anyone who has done this job or better still a link to the correct adapters would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
problemchild Posted July 27, 2017 Share Posted July 27, 2017 i replaced my Speakers with OEM again for a few £ as they sound sweet and the OEM head unit is superb i think when you take the Speakers out the hole is bigger but i forget now. door card pop off (buy some spares as they snap and be careful as some of the mounts are only glued onto the door card) there is a screw in the door handle this revels a screw behind there is a screw under the door storage area JJ Quote Link to comment Share on other sites More sharing options...
Saxosim Posted July 29, 2017 Author Share Posted July 29, 2017 Thanks JJ I shall give that a try I was wondering how the door cards come off. I have got some plastic trim removal tools so hopefully I can get it off the door with no damage. Quote Link to comment Share on other sites More sharing options...
marco.da.man Posted August 6, 2017 Share Posted August 6, 2017 hi mate if you tilt the seats forward you will find two area's for i believe to fit rear 6 x 9 Speakers as an extra, the connectors should also be there. i believe these could easily be adapted to fit after market ones also 1 Quote Link to comment Share on other sites More sharing options...
Suicide Mods Posted April 28, 2018 Share Posted April 28, 2018 On 8/6/2017 at 4:58 PM, marco.da.man said: hi mate if you tilt the seats forward you will find two area's for i believe to fit rear 6 x 9 speakers as an extra, the connectors should also be there. i believe these could easily be adapted to fit after market ones also Oooo found by accident will look into this myself. Thank you! Quote Link to comment Share on other sites More sharing options...
