1.6TDCI Boost issue
Liam121093
Hello
My car is really frustrating me now it works fine on the flat or up a steep hill but if I go up a long hill my boost cuts from 18-21psi to about 5-6psi usually in 3rd.
I have checked all pipes I have changed the map sensor and MAF sensor.
Checked wastegate is holding vacuum.
Any idea or suggestions would be greatly appreciated
Does the 1.6 TDCI have an electronic actuator on the Turbo......it might be worth a look.
No bud it has a vacuum solenoid that controls the the wastegate.
Ok , it sounds like the turbo is not producing boost and the engine is "sucking" on the turbo pipes instead of them being under pressure
Even though you can hear the turbo spooling i would double check to see if its turning ok and has not got a lot of play in it (you can take the inlet hose off the front of the turbo to do this)
could be siezed or seals have gone
if its a fixed vane the wastegate may be jammed open
variable vane - faulty actuator
could be a blockage upstream of the turbo
or the EGR valve stuck open or a leak before the turbine
i would keep an eye on the oil level to see if it is using oil
i would get a code reader see if faults come up mate.
Turbo will work lovely on the flat but for some reason on long uphill the turbo almost cuts out.
I have forscan and I'm getting turbo uderboost but not showing eml.
Egr has been mapped out and blanked.
I have checked for play and there's nothing shaft spins freely. There is oil from the centre of the turbo running down the back of the inlet side of the turbo.
There is a common bolt hard to tighten on the 1.6 that I think can cause oil leak YouTube it or google images mate
So today I did a static regeneration because I can't go on the motorway due to turbo cutting out.
I noticed exhaust gases escaping between the turbo and dpf, I checked the clamp and all is tight.
My boost still cuts out no idea why but I think I might have to buy a turbo see if that works, What do you guys think ?
Turns out its the boost solenoid on the back of the engine just hope it works fully now
  • Like 2
