jimmy46 Posted August 23, 2017 Share Posted August 23, 2017 Hi Guys in also looking to fit ST 250 gauges to my Focus is it easy to cut top of dash to clip it in? Thanks Jimmy Quote Link to comment Share on other sites More sharing options...
yunii Posted August 23, 2017 Share Posted August 23, 2017 Hi Guys in also looking to fit ST 250 gauges to my Focus is it easy to cut top of dash to clip it in? Thanks Jimmy Your dashboard loom will be completely different. It wont work exactly like in st but maybe possible to have them illumenated. I had st170 gauges & speedo in my mk1.5 2.0 zetec esp. YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
yunii Posted August 23, 2017 Share Posted August 23, 2017 Btw i fitted this in my mk2.5 Titanium -S .this is scangauge ii diagnostic unit fitted in st225 gauges housing.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
jimmy46 Posted August 23, 2017 Author Share Posted August 23, 2017 Looks good on your car lm just wanting mine for looks done really care if the work or not thanks jimmy Quote Link to comment Share on other sites More sharing options...
yunii Posted August 23, 2017 Share Posted August 23, 2017 I already had a storage tray on top of dashboard so i removed the lid & custom fitted gauges. But lenny & preee did in his mk3YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
yunii Posted August 23, 2017 Share Posted August 23, 2017 Better imageDont know why its sidewaysSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
jimmy46 Posted August 23, 2017 Author Share Posted August 23, 2017 My dash has lines on it but not a cut out you can just pop off 😩 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 23, 2017 Share Posted August 23, 2017 If you remove the radio screen then you can feel the cut areas from the inside.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
JW1982 Posted August 24, 2017 Share Posted August 24, 2017 The additional MK3 ST gauges are fully functional on the 1.5 ECOboost. On all other engine types the additional gauges have limited functionality or no functionality at all. The additional ST gauges are CANbus controlled. It is possible to control the gauges with a suitible controller (for example an arduino combined with a CANbus shield). However this requires a custom written arduino sketch. You basically need to convert the input data to a suitible output data that is transmitted to the gauges. I did this before for the additional MK2 ST gauges. Quote Link to comment Share on other sites More sharing options...
