Edd1971 Posted September 2, 2017 Share Posted September 2, 2017 My wife's 2001 ka has developed an issue with the indicators, it is still in very good condition only covered 30k. Basically they don't work but the hazards do , I've changed the fuses the switch and even the steering column stalks. It can't be a bulb issue as I said earlier the hazards work fine. The green arrows on the dash do not light up though. I'm literally at a loss. Any advice would be great thanks. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 2, 2017 Share Posted September 2, 2017 Relay?I believe that the indicator and hazard relays are seperate?Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Edd1971 Posted September 2, 2017 Author Share Posted September 2, 2017 Excuse my ignorance but where would I find the relay.. Quote Link to comment Share on other sites More sharing options...
Edd1971 Posted September 2, 2017 Author Share Posted September 2, 2017 11 minutes ago, Edd1971 said: Excuse my ignorance but where would I find the relay.. I've found the relays but how do I determine which one is for the indicators . Apologies for the daft questions Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 2, 2017 Share Posted September 2, 2017 Indicator relays will click when engaged, same as front & rear wipers (& headlights also I believe).Process of elimination should work or remove each relay in turn and test- Sent from my SM-G930F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Edd1971 Posted September 2, 2017 Author Share Posted September 2, 2017 Thank you will try this tomorrow 1 Quote Link to comment Share on other sites More sharing options...
Edd1971 Posted September 3, 2017 Author Share Posted September 3, 2017 Thank you so for your help.. I've now solved the problem it was fuse 22 I did change this first off but it must of been faulty from the box. I purchased it from Halfords brand new but it was obviously faulty. Again thank you all. Sent from my SM-G930F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
