m_fairfax Posted September 12, 2017 Share Posted September 12, 2017 Hi all, An issue arose last night with the round dial that selects the direction that air blows from in my fiesta last night. All was working as normal and air was blowing on windscreen. Turned the direction to feet and something didn't feel right. Air will only now blow straight at me and nowhere else. There used to be a bit of tension when turning the dial indicating that something was changing the direction however now there is no tension when changing positions. Any advice would be greatly appreciated. Car is a mk7/mk7.5 (unsure - 63 plate zetec s 1.6tdi) fiesta Cheers Quote Link to comment Share on other sites More sharing options...
Alex93 Posted December 28, 2017 Share Posted December 28, 2017 Hey, Have you managed to get this fixed? I have exactly the same issue on my 2013 Ford fiesta ecoboost. Happened the same as you said yours happened. I've managed to get behind the glove box and can see the insides of the selector trying to work when spinning the dial on the dash, but it doesn't move enough to change the airflow direction. Any feedback would be greatly appreciated :) Alex Quote Link to comment Share on other sites More sharing options...
HLENNIE Posted January 7, 2018 Share Posted January 7, 2018 u need to remove the heater selector then reclip the connecting cable to the back of the selector quite fiddly though. first u need to remove gear stick surround then i think its a couple of torx screws holding the heating controls in place. suggest u buy the Haynes manual u cant go wrong then Quote Link to comment Share on other sites More sharing options...
TDR|XTC Posted January 7, 2018 Share Posted January 7, 2018 As above! Those 2 cables are attached behind your center console on 2 small clips (green one in the picture). Check behind to see if those have popped out. If not, then the problem might be on the heater controls. The cables can pop-off or some clips are broken. Hope it helps Quote Link to comment Share on other sites More sharing options...
