AUX not working, help :x!
Velse
 Share
Hello all,
I am having problems with the AUX on my fiesta.
We bought it second hand and the USB/AUX were not working. I fixed the USB, turned out the fuse was blown and the power outlet was in not too good shape... So I replaced the fuse and the power outlet for a new original Ford piece. Now the power outlet works, and so the USB I plugged in.
The AUX, however... the console shows me the Line In message, but when I plug it to my phone playing music though different sources, it just won´t play the audio on the car Speakers. The cable is good, I bought a new one and it does work.
The fuses are okay, the AUX port I have inspected and it looks okay as well. Everything works but that.... if it helps, the voice command doesn´t work and neither the cruise control (but I don´t care much about the last).
It is a Fiesta 1.25 from 2010.
Do you have any idea what might be causing it?
I´ve looked all over but none else seems to have this problem... my bluetooth seems to work, it find the phone and I can access the call list ad contact from the car and so on. It is simply the AUX play... also played with volumes and audio settings, everything is as it should be. just the thing won´t play on the car Speakers!
Link to comment
i have a slightly lower model,but it has AUX JACK AS WELL JUST WONT WORK THROUGH MOBILE,IVE Tried ANDROID APPLE,i heard nokia symbian worked when thy came out,mentions it in the manual.but i no longer have one,i cant get it to play burnt discs either...
Link to comment
Problem solved!
(Solution)
I was not going to give up on this issue!
This fixed both the audio streaming and the voice command functions. The cruise control was functioning all the time, I was just failing to make it work... go figure :blush:
So all it toke was some fuse resetting/replacement.
You will need to check which fuse box you have, mostly type one or two if your Fiesta is from around 2010 like mine. Find the fuses for bluetooth and Audio Sync, one is 15 Amp (BT) and the other is 7.5 Amp (audio sync system). Technically, you could restart them but I wanted the car´s computer to fully get the message (that I am in fact replacing those fuses), because they did look in good shape but I it HAD to be that.
1- With your car off, remove both fuses. Turn the car on and of course the whole audio system won´t work.
2- Turn off the car and insert new fuses where you toke the old ones out, they cost peanuts anyway so just get new ones.
3- Turn on the car and enjoy! (remember to first plug your device through USB, then AUX, and remember to max your device´s audio for optimal performance).
Now all the normal procedure to connect should work. If this doesn´t help you, inspect your USB and AUX jacks (physically). They could be damaged, if not, I honestly suggest you to check with Ford.
Link to comment
  • 3 years later...
Hi. I wonder if you can help me. I have a 2009 ford fiesta however the bluetooth, aux and usb don't work. It won't let me turn the bluetooth on from the stereo. I have tried another bluetooth module and it didn't work. The head unit wiring is all fine as I have removed that as well. Do you think a setting using obd may be needed to turn on bluetooth? I tried to do an update on the Bluetooth module using usb however the usb isn't recognising anything. Thank you
Thanknk you Freddie
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
