Water gathering into top strut mount
Honglee
Hello, I'm new to this forum and got a fusion no long ago, recently I notice that water gathering into driver side top strut mount, It looks not good. Is there any way that could stop water gathering into? Thanks.
same problem here, not sure if some kind of grommet should be in place ?
I have the same problem it seems design fault... maybe some custom made cap?!
Somewhere in the forum another member came up with a fix on a fiesta. Have a browse around the fiesta Section 👍
Yep me too,im gonna dry the cavity out thoroughly,pack it with grease then  find a plastic cap/lid to place over the top.
  • 1 month later...
Dry it out, fill the cavity with oil, fit a 99p 32mm blanking grommet.
  • Thanks 1
  • 2 years later...
look carefully and youl'l see a small drain hole towards the the back just clear it with a piece of wire
  • Thanks 1
  • 5 months later...
Yes look around the top of the strut and you will see a small drain slot clear it with a piece of wire etc.
