Newtsy69 Posted October 18, 2017 Share Posted October 18, 2017 hi all, can someone help please , I’m driving a Ford Mondeo titanium x sport 2010, I keep getting a wet floor well on the drivers side , does anybody know what it could be, some people have been saying all sorts of things like it’s the windscreen, pollen filter, wheel arch hole or door seals! Any body know an easy way to eliminate the wrong ones or an easy way to check please. Quote Link to comment Share on other sites More sharing options...
kingsblue Posted October 18, 2017 Share Posted October 18, 2017 Are you sure it's rain water or could it be coolant? Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 18, 2017 Author Share Posted October 18, 2017 Yeas it’s definatly water as it’s not got that distinctive smell of coolant Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 most likely is air con drain tube seal , theres a few threads about it on here sonewhere. i will have a look and post up link Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 18, 2017 Author Share Posted October 18, 2017 Thank you Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 and Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 18, 2017 Author Share Posted October 18, 2017 Thank you so much I’ll have a read Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 18, 2017 Author Share Posted October 18, 2017 Quite easy to check then, just pop that cover off on the left hand side of the foot well and there should be that white drain plug, just pop that off with a screwdriver and see if it’s blocked! Hope fully it is and that’s the problem Quote Link to comment Share on other sites More sharing options...
iantt Posted October 18, 2017 Share Posted October 18, 2017 yep, thats about it. let us know what you find. Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 18, 2017 Author Share Posted October 18, 2017 Ok I will do, thanks for your help Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 20, 2017 Author Share Posted October 20, 2017 Hi, popped off the drain plug and it’s clear as a whistle, got to be something else I think?? Quote Link to comment Share on other sites More sharing options...
iantt Posted October 20, 2017 Share Posted October 20, 2017 Did you check the other end also Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 20, 2017 Author Share Posted October 20, 2017 How do I get to the other end?? It seemed to go downwards. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 20, 2017 Share Posted October 20, 2017 Just lift the carpet back a bit, the other end unclips from the body. Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 20, 2017 Author Share Posted October 20, 2017 Just had a look, it’s clean but looks like a clip is broke, might have kicked it or something and it is damp in that area, any idea what this hose is called so I could buy a replacement or could I just fix it with a bit of silicone? Quote Link to comment Share on other sites More sharing options...
iantt Posted October 20, 2017 Share Posted October 20, 2017 some on here have siliconed the seal and fixes it, Quote Link to comment Share on other sites More sharing options...
Newtsy69 Posted October 20, 2017 Author Share Posted October 20, 2017 Ok I’ll give it a go tomorrow, thanks for all your help Quote Link to comment Share on other sites More sharing options...
