AndrewAfresh Posted October 23, 2017 Share Posted October 23, 2017 I've had about three cig chargers which I use for an android phone and they seem to be blowing the fuse – any ideas why? Could it be triggered by stalling? Thank you if you can help. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 24, 2017 Share Posted October 24, 2017 What size fuse is fitted?Iirc it should be 20A.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Micro Posted October 25, 2017 Share Posted October 25, 2017 Check your socket is clean inside with no loose bits of metal (foil!) inside it. Have you tried a decent cig adapter (i.e. for sat nav) to see if that blows it? Is it just when you plug something into the socket, or as soon as you replace the fuse? A single phone charger should draw no more than 3-5A max (5V 3A is 15W, so even at 50% efficiency you're talking a max of 12V 3A ish input). Quote Link to comment Share on other sites More sharing options...
