Ecobo0st Posted October 27, 2017 Share Posted October 27, 2017 Hi all, I need to replace the passenger side wing mirror on my 2016 st line, will a wing mirror from a 2016 ST fit? Thanks Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
isetta Posted October 27, 2017 Share Posted October 27, 2017 you will accuse me of being pedantic, but it's a door mirror not a wing mirror this is a car with wing mirrors. Cars stopped having wing mirrors on in the 1970s 2 Quote Link to comment Share on other sites More sharing options...
Bobr Posted October 27, 2017 Share Posted October 27, 2017 It is a fairly easy job. Remove the rubber bung in the door (after taking off the door board) and disconnect the plug. Unscrew he nut and it will just pull out. A very good tip is to tie a piece of string to the plug so that you can use it to pull the new wiring into place; otherwise it's a hell of a job to feed it through. 1 Quote Link to comment Share on other sites More sharing options...
karl46 Posted October 28, 2017 Share Posted October 28, 2017 Why do you need to remove the "door board" whatever that is, the rubber bung is readily accessible just by opening the door. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 28, 2017 Share Posted October 28, 2017 door card needs to come off to access the wiring and plug. Quote Link to comment Share on other sites More sharing options...
ToXIcG Posted October 29, 2017 Share Posted October 29, 2017 5 hours ago, iantt said: door card needs to come off to access the wiring and plug. 6 hours ago, karl46 said: Why do you need to remove the "door board" whatever that is, the rubber bung is readily accessible just by opening the door. On 27/10/2017 at 6:30 PM, Bobr said: It is a fairly easy job. Remove the rubber bung in the door (after taking off the door board) and disconnect the plug. Unscrew he nut and it will just pull out. A very good tip is to tie a piece of string to the plug so that you can use it to pull the new wiring into place; otherwise it's a hell of a job to feed it through. I know you guys are just trying to help but it seems like he is asking will one from a different (albeit similar) car fit not how to actually do it. :) I wish I could help you here but I don't have a clue i'm afraid, I would assume so but can't say for sure. Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted October 29, 2017 Share Posted October 29, 2017 You would need to check that the mirror you want to replace has the same spec as yours (I.e. Is it power folding, puddle light, heated, sale convex style, etc). An ST mirror will physically fit. Quote Link to comment Share on other sites More sharing options...
Ecobo0st Posted October 29, 2017 Author Share Posted October 29, 2017 Thanks to all for your replies, helps a lot [emoji106]Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Bobr Posted October 29, 2017 Share Posted October 29, 2017 I fitted a non folding mirror in place of the folding type on a 2009 Fiesta. I bought it of eBay for a few quid whereas the actual match to the mirror cost a small fortune. The string tip is good though whatever the mirror as it saves a lot of fiddling (and time) to get the cable in place. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 29, 2017 Share Posted October 29, 2017 agree,string tip is good idea. can quite easily route the cable the wrong way round the window channel. had a few customers in who fitted there own mirror and couldnt understand why there window wouldnt go all the way down. Quote Link to comment Share on other sites More sharing options...
