Rhuddlan Fusion Posted October 28, 2017 Share Posted October 28, 2017 Got a clonky knocking noise over the rear drivers side wheel area,dont know if its the bearing or something in the suspension set up,determined to get this Fusion running right. Quote Link to comment Share on other sites More sharing options...
isetta Posted November 1, 2017 Share Posted November 1, 2017 if you jack it up and spin the wheel and grab hold of it at 6 oclock and 12 o clock position and try rocking it (with brake off) you should be able to tell if bearing has play or roughness. Make sure car is securely chocked when jacked up with brake off. and make sure there is also something else supporting it - not just jack, so it does not crush your fingers between road and tyre Quote Link to comment Share on other sites More sharing options...
