Sign in to follow this
24008943
Emergency key
Hi all , have a new 2017 ecosport Titanium Automatic 1.5 with keyless entry,start.
If ever the fob battery dies  ,  i realise there is a door key inside the fob ,once the doors are opened with it would the car still start ok even with a dead battery in the fob ?... i know i could give it a go now, but not sure if it would cause any problems with the fobs memory,etc.
There will be a marked location (in my car it's under the armrest).
The key just gets placed on to the marked area and it works just like the PATS ring used to on key ignitions.
  • The passive key frequencies are jammed.
  • The passive key battery has no charge.
If you are unable to start your vehicle, do the following.
Missing Image
  1. Hold the passive key next to the symbol on the steering column.
  1. With the passive key in this position, you can use the button to switch the ignition on and start your vehicle.
Many thanks for the replies , very helpful.
The last Ford i owned was in 1968 , a Zodiac , i was the real " bee's knees" in that, with a crackly Radiomobile fitted in it , 'oh happy days :smile:
  Only 75 emoji are allowed.
