Media unit
Just want to know if anyone has used one of these...
Thinking of getting it for my fiesta but just want to know if they are worth the money...
Also if they are as simple to install as it makes out lol
By the looks of it it has those 4 slots which you would put a key in to release the stereo from the cage so removing and installing won't be a problem.
Also what's the name of this stereo as I've never seen it. Some mk6 fiesta came with a Sony stereo which I think you should also look into. I was thinking of getting the Sony stereo and try to get it with DAB
You have to be careful with aftermarket touch screen head units from ebay, amazon etc. Quite a lot are cheap chinese crap that's slow to respond and crashes a lot.
Install is easy if the wiring has the same connector on.
Apparently these are just a straight swap ford the ford 6000 unit but just wanted to know if someone has used it...
Thanks for the replys
The mark 6 is quite easy to convert allowing any aftermarket radio to fit as said previously the Chinese ones tend to be cheap for a reason.
i had one of them in my old mondeo from ebay as long as you get the ford one with the right loom connecter should be all good as mine was
