Fiesta Ecoboost '13 floor mat wet...
RockandGrohl
Apologies if this is a simple one. My floor mat appears to be wet, on the rubber directly between the accelerator and brake pedals. This appears to be wetter than it would be if it was just water on the bottom of my shoe, it's always in the same place (despite the never being any residual water on the left side where my foot rests when it's not on the clutch) and seems to persist, the day after it rains for example I will get in the car in the morning and there will be that wet spot still there.
Possible that water is leaking from under the dash somehow?
There's a couple of grommets under the dash that are known to leak. The water runs down ancable that passes through the grommet. Get under with a flashlight and you should be able to spot it. Some silicone sealant would fix it or replace the grommet.
