Can't get mobile to sync with car
I drive a ford fiesta ecoboost 1l 2015.  My phone (Moto g 2nd gen) has been connected for just over two years, no problems. All of a sudden my phone won't connect, I've google it and tried lots of different things, as a last resort I did a master reset and tried to add it again and it won't work. I get to the bit on the car display where it says please find sync on your phone and press it, and the display on the car shows the 6 digit pin it wants me to enter. In my phone when it searches for device it displays sync (which is black) I press on it so it greys out and underneath it says pairing and then after a little while nothing happens and the word sync on my phone goes to black again. It's so annoying, hoping someone might have had a similar issue and have been able to resolve? Thanks
Try clearing car out Bluetooth list and rebooting the phone then try to sync phone to your car
Best thing to do is switch the car off, pull out the fuse and replace it. This normally fixes the problem.
+1 for pulling the fuse, sorry I don’t know which one it is though. This has worked for several members.
If you don’t fancy doing that then go into the cars Bluetooth settings and delete all the previously paired devices, same on your phone and make sure your phone is ‘visible’ to all external devices. Then turn the ignition to ON but do not start the car and go through the pairing steps you have previously followed, this time though make sure your phone is in your left hand at about shoulder height while your right hand touches the wing mirror*. Your phone may have received an OTA update recently which has just changed a few things.
*may not be necessary to do previous steps
I use an iPhone 5S and, after the last update to IOS 11.1.1 , I had all sorts of problems trying to use it to call someone through the car's system.
Whereabouts is the fuse?
behind the glovebox
