alexp999 Posted July 19, 2020 Share Posted July 19, 2020 You only get that setting with adaptive headlights on the mk4. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2020 Share Posted July 21, 2020 Sorry for late reply - didn't get a notification. Yes I have the full adaptive headlights. Quote Link to comment Share on other sites More sharing options...
vibeone Posted August 22, 2020 Share Posted August 22, 2020 It’s set up correctly for left hand traffic? Quote Link to comment Share on other sites More sharing options...
KevG Posted January 20, 2021 Share Posted January 20, 2021 I gather this for Mk3/3.5 Focus with Xenon Headlights? No mention of this menu in normal halogen lit vehicles. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 20, 2021 Share Posted January 20, 2021 19 minutes ago, KevG said: I gather this for Mk3/3.5 Focus with Xenon Headlights? No mention of this menu in normal halogen lit vehicles. Correct. If you're going abroad you'll still need adhesive beam adjusters for halogens. Quote Link to comment Share on other sites More sharing options...
Paul9619 Posted January 20, 2021 Share Posted January 20, 2021 I have a Mk4 TX. As far as I know and according to the brochure there are three headlight varients: 1. Halogen 2. Fixed Full LED 3. Adaptive full LED I thought mine were fixed full LED but I have an adaptive light setting for L/R in the settings. Is this setting not on both the fixed and adaptive versions? Quote Link to comment Share on other sites More sharing options...
karlbbb Posted February 2, 2021 Share Posted February 2, 2021 On 1/20/2021 at 9:30 PM, Paul9619 said: I have a Mk4 TX. As far as I know and according to the brochure there are three headlight varients: 1. Halogen 2. Fixed Full LED 3. Adaptive full LED I thought mine were fixed full LED but I have an adaptive light setting for L/R in the settings. Is this setting not on both the fixed and adaptive versions? If you change the setting, do you see a different in the beam pattern? If you lights look like this below, you have the fixed LED lights: Adaptive LEDs look like this: Also worth noting that from late 2020, even the bog-standard "reflector" headlamps now have an LED for dipped beam, with halogen for high beam, so there's currently 4 different headlamps you could have on a Mk4. That said, if it's a Titanium X like you said, it will only be one of the two types that I added pictures of, with the fixed as standard and adaptive as an option. Quote Link to comment Share on other sites More sharing options...
Paul9619 Posted February 2, 2021 Share Posted February 2, 2021 I have the fixed LEDs then 👍. LED for dipped and main beam. They auto level on switch on which is the only movement I see. Adaptive Left/Right menu must just be to set where the fixed part points. Quote Link to comment Share on other sites More sharing options...
karlbbb Posted February 3, 2021 Share Posted February 3, 2021 11 hours ago, Paul9619 said: I have the fixed LEDs then 👍. LED for dipped and main beam. They auto level on switch on which is the only movement I see. Adaptive Left/Right menu must just be to set where the fixed part points. Cool, glad that was cleared up! Do you actually see a difference if you change the traffic setting? Quote Link to comment Share on other sites More sharing options...
Paul9619 Posted February 3, 2021 Share Posted February 3, 2021 11 hours ago, karlbbb said: Cool, glad that was cleared up! Do you actually see a difference if you change the traffic setting? I’ll have a try tomorrow and let you know Quote Link to comment Share on other sites More sharing options...
Gixer73 Posted October 18, 2021 Share Posted October 18, 2021 Hi i recently bought a 2019 Focus with the adaptive headlights. Everytime they are on i always get flashed. Have checked the Traffic Setup and its set to LEFT which i believe is correct for driving in the UK. it looks to me like the system is slow to react to oncoming traffic and doesn’t adjust/dip the offside beam quickly enough meaning its blinding oncoming traffic, to the point where i have to turn the lights to manual so it disables the adaptive lights. any ideas? As i do love the adaptive lights and really want to use them. Many Thanks Quote Link to comment Share on other sites More sharing options...
alexp999 Posted October 18, 2021 Share Posted October 18, 2021 1 hour ago, Gixer73 said: Hi i recently bought a 2019 Focus with the adaptive headlights. Everytime they are on i always get flashed. Have checked the Traffic Setup and its set to LEFT which i believe is correct for driving in the UK. it looks to me like the system is slow to react to oncoming traffic and doesn’t adjust/dip the offside beam quickly enough meaning its blinding oncoming traffic, to the point where i have to turn the lights to manual so it disables the adaptive lights. any ideas? As i do love the adaptive lights and really want to use them. Many Thanks Sounds like the anti glare high beam you are talking about, rather than the Left right setting. They are slow to create the "shadow" sometimes. And often people will flash you if they've seen your lights coming round the corner and they can't see them dip. I often manually dip them in some scenarios, not much you can do unfortunately. It's not good at spotting people a long way off and if you are going up an incline they can particularly slow as the shadow forms from the top of the pattern down, so it takes a while to reach the oncoming car. You can dip them, and then raise them again and it creates the shadown around them, I often do that as cars get closer or have appeared fully around the corner, so I have the advantage of high beam around the oncoming car, but they don't get any high beam even momentarily. Quote Link to comment Share on other sites More sharing options...
Botus Posted July 24, 2022 Share Posted July 24, 2022 On 11/21/2017 at 11:16 PM, Zico said: The setting is for which side of the car you drive on and also for which side of the road. UK is right hand drive and EU continent is left hand drive. also known as the correct side and the wrong side nature created most humans (90% ish) to be right handed and there are LOTS of reasons why we should drive on the correct side of the road like we do in the UK, Oz, NZ, RSA, Botswana, Japan, India etc. - it was a temper tantrum by a small left handed French bloke that got many driving on the wrong side - a remarkable achievement to get so many lemmings to follow suit - the last country to change moved to the correct side by the way... 1 Quote Link to comment Share on other sites More sharing options...
Botus Posted July 24, 2022 Share Posted July 24, 2022 On 11/23/2017 at 4:02 PM, Dee_82 said: So does that change your actual pattern then? or just direct it a bit to the left or right of centre? when done correctly there has always been a flick up to the nearside to better highlight the side of the road, and to show pedestrians and cyclists - both the correct right hand drive cars, and the wrong left hand drive countries have this (its why when you drive on the wrong side of the road it dazzles the other driver). With changes in design and to reduce costs of building two different lamps many modern cars can tweak the pattern to suit driving on the correct side or for the wrong side of the road circa 2000 with xenon's some lazy manu offered a built in bodge to kill the flick up to the nearside, and went with a flat beam option - but its not as safe / reassuring as doing it right Quote Link to comment Share on other sites More sharing options...
