Misfire Cured 2006 1.25 Style Climate
I give up, I’m very confused.
I’ve been fighting with misfires for a couple of years now and replaced all the usual suspects like plugs, coil pack and cured water leaking into the spark plug cavity.
Then I got a new misfire at idle and lack of power on the motorway unless I was flat out.
Diagnosis and speaking to a Ford tech pointed to the throttle body which is expensive so I was holding off from the purchase till after Xmas.
Then the battery started failing so I had to replace it (original 2006 battery)
Ever since the misfire is not there anymore ??
How does a battery cure a misfire?????
I don’t get it !
Not enough juice for it to give the spark plugs enough spark I guess.
11 years is very good for a car battery.
If it comes back clean the throttle body rather than replacing it. I doubt it will have a fault that can't be fixed by cleaning.
