Azul1 Posted January 25, 2010 Share Posted January 25, 2010 Hi guys Looking for a little help if you can. Relaced a headlight bulb the other day On checking it out afterward the whole lamp seems to be Kaput The indicator, side light and headlight do not work I have checked the fuse's in both box's and all are OK anyone any ideas here is it a new lamp I looking at here I did notice the socket that you plug the loom into on replacing the lamp unit was pushed right into the lamp unit. and I had to pull this out to connect the plug, could this have caused soem damage is there anyway, to see if the loom is working If I took the other lamp out and plugged it in that side are the looms wired so they could work on both lamps or would the plug differ either side Quote Link to comment Share on other sites More sharing options...
Azul1 Posted January 25, 2010 Author Share Posted January 25, 2010 Hi guysLooking for a little help if you can. Relaced a headlight bulb the other day On checking it out afterward the whole lamp seems to be Kaput The indicator, side light and headlight do not work I have checked the fuse's in both box's and all are OK anyone any ideas here is it a new lamp I looking at here I did notice the socket that you plug the loom into on replacing the lamp unit was pushed right into the lamp unit. and I had to pull this out to connect the plug, could this have caused soem damage is there anyway, to see if the loom is working If I took the other lamp out and plugged it in that side are the looms wired so they could work on both lamps or would the plug differ either side Cmon guys some help this post is getting lost down the line anyone have any ideas please Quote Link to comment Share on other sites More sharing options...
