coreykelly Posted December 27, 2017 Share Posted December 27, 2017 I was driving my 05 get 1.6 focus 110 bhp down the motorway and at about 110km/h engine system fault came up on dash and I couldn’t go over 3k revs. Plugged it in when I got home with forscan and it gave me the code P0229 which said “underboost”. Has anyone any ideas might it what be and when to check. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted December 28, 2017 Share Posted December 28, 2017 Quote check your boost pipes, theres a hose at the top at the front in the middle, that connects to a metal pipe which crosses to the near side then drops down under the airbox, theres a second hose that connects from that pipe to the intercooler, then on the Offside of the car yfou will see another longer hose coming out of the intercooling up to the a plastic connection which eventually heads in to the intake manifold. you want to check all three rubber hoses and the metal pipe for holes or splits. check that metal pipe around the welded brackets, on early versions of the car they were a common problem for splitting on the weld. Quote Link to comment Share on other sites More sharing options...
