Tommo17 Posted December 30, 2017 Share Posted December 30, 2017 Hello people. Hope we all had a good Christmas. Couple of of questions for you fine folk. after upgrading the display to sat nav display I have an annoying problem, when I turn the car on the display shows blank station name I’ll switch stations and it now shows up. Any ideas ? Also so with the cold weather I’ve notice on the larger cluster screen display the frost light only stays orange and doesn’t change to red? Is that correct on the larger displays Thanks people. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 30, 2017 Share Posted December 30, 2017 Is the sat nav system configured correctly in the Central Car Configuration? The orange frost warning on the instrument cluster display is completely normal. On the more recent instrument cluster software versions Ford removed the red frost warning. Many people confused the red frost warning with an engine problem. On the more recent software versions the frost warning remains orange and is no longer red below 0 degrees Celcius. 1 Quote Link to comment Share on other sites More sharing options...
andypsp Posted December 30, 2017 Share Posted December 30, 2017 23 minutes ago, Tommo17 said: I’ve notice on the larger cluster screen display the frost light only stays orange and doesn’t change to red? think you`ll find it will change to red when it gets to -1 and below. between 0 and 5 it stays orange Quote Link to comment Share on other sites More sharing options...
Tommo17 Posted December 30, 2017 Author Share Posted December 30, 2017 Thanks JW i think it is. Everything works perfect apart from that. Also a shame the speed limit of the road doesn’t display on the cluster display. Quote Link to comment Share on other sites More sharing options...
Tommo17 Posted December 30, 2017 Author Share Posted December 30, 2017 13 minutes ago, andypsp said: think you`ll find it will change to red when it gets to -1 and below. between 0 and 5 it stays orange It used to, but doesn’t now. JW cleared that up Quote Link to comment Share on other sites More sharing options...
Tommo17 Posted December 30, 2017 Author Share Posted December 30, 2017 4 hours ago, JW1982 said: Is the sat nav system configured correctly in the Central Car Configuration? The orange frost warning on the instrument cluster display is completely normal. On the more recent instrument cluster software versions Ford removed the red frost warning. Many people confused the red frost warning with an engine problem. On the more recent software versions the frost warning remains orange and is no longer red below 0 degrees Celcius. Hi pal been out with the laptop checked I had the none touch mfd 5 option on under the nav settings. And it is so not sure what else it could be. Next issue I’ve notice and I’m not sure how I’m doing it. Can’t Pm you with pictures so have to do it here. When I checked settingsis focccus I hit write. Then noticed my cluster display changed to the darker colour one. Do you know what I’ve done? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 30, 2017 Share Posted December 30, 2017 MFD5 is the correct setting so it is not a display configuration issue. When selecting the 8 inch touchscreen the instrument cluster automatically changes to the black/dark color scheme. 1 Quote Link to comment Share on other sites More sharing options...
