Sign in to follow this
GFoster
MK2 Boot Switch fuse number???
New member here and looking for some help please!! :)
I believe this is related to the known MK2 rear water leak (been heavy rain here all last week), got a warning that boot was open while driving so pulled over and sure enough it was. Closed it and happened again a few mins later. Now happens randomly. When using the fob to unlock doors, the boot no longer unlocks and the button under the "flap" doesn't either, it will only unlock using the boot button on the fob. The mechanism/solenoid is obviously fine as it locks and unlocks with the fob, so assuming that water ingress has shorted out the switch, which I can easily replace but can't quite afford for a couple of weeks.
Question is, what is the fuse number that controls this switch, so I can temporarily remove it to stop the random unlocking whilst driving? I've searched around and it might be #77? If anyone can help with up to date info that would be great :) Cheers
G
Its the actual boot switch thats failed - the one under the rubber flap that you press to lift the boot.
I actually replaced mine yesterday with exactly the same symptoms - it wont be the fuse.
They are 6 quid on ebay or 30 from ford
I wouldnt be pulling the central locking fuse if im honest , can see that ending in tears , just unplug the switch from the boot lock but you might as well just change it .....
I wouldnt be pulling the central locking fuse if im honest , can see that ending in tears.....
Thanks Pete,
So that fuse would also be the central locking one, didn't think of that. Supposed to doing a 300+ mile round trip to Manchester on Wed and didn't fancy the boot randomly opening on the motorway! What issues do you think it could cause taking that fuse out?
No idea , im not dumb enough to try it ;-)
Like i said unplug the switch from boot lock which will stop it opening unexpectedly until you can replace it
Doh, yeah, that would do the same thing wouldn't it! Cheers!
I've got the same problem,, boot opens on fob boot button but not on door button. Have tested the micro switch on the boot release button that's ok. Not sure what to try next.
I changed my switch and it’s started happening a week later so something more must be to blame. It happens when I press the brake so I can only assume it’s the whole wiring in the boot area
  Only 75 emoji are allowed.
