agentil Posted January 8, 2018 Share Posted January 8, 2018 Hi all, I think I have a problem on my last acquisition, a Ford Focus MK2 (2206) 1.8 petrol Duratec HE 125hp. The temperature gauge rarely get off of 60 "degrees C". I check that sometimes it increases a little but never reaches the first step and it comes again to 60 degrees. I found on the web a similar speedometer that explains the behaviour of my car (note: is not from my car): Based on my other cars, usually the temperature gauge goes to the middle. So I think that should not be the default behaviour of the Focus. The coolant is ok, the engine also seems to work weel. What do you think that the problem is? Thanks for your help. Cheers. Quote Link to comment Share on other sites More sharing options...
iantt Posted January 8, 2018 Share Posted January 8, 2018 thermostat stuck open. 1 Quote Link to comment Share on other sites More sharing options...
agentil Posted January 9, 2018 Author Share Posted January 9, 2018 2 hours ago, iantt said: thermostat stuck open. Hi Iantt, Make sense. I was thinking that could be a problem on temperature sensor but after reading more about thermostat stuck open I check that a symptom was the ventilation hot temperature is not so hot as suppose to be. I realised last weekend when turned on the ventilation. Thanks for your help! :) Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted January 9, 2018 Share Posted January 9, 2018 Hi, Mine is a 1.8 and it sits just below the middle. I think your thermostat is stuck open. 1 Quote Link to comment Share on other sites More sharing options...
agentil Posted January 10, 2018 Author Share Posted January 10, 2018 On 1/9/2018 at 9:01 AM, JONATHAN_11_80 said: Hi, Mine is a 1.8 and it sits just below the middle. I think your thermostat is stuck open. Thanks Jonathan for your feedback. I will change thermostat and then give feedback here. ;) 1 Quote Link to comment Share on other sites More sharing options...
agentil Posted January 16, 2018 Author Share Posted January 16, 2018 Hi all! Just to give you feedback! I changed the thermostat and it fix the problem! Thanks to all that help! :) 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted January 17, 2018 Share Posted January 17, 2018 On 16/01/2018 at 1:06 AM, agentil said: Hi all! Just to give you feedback! I changed the thermostat and it fix the problem! Thanks to all that help! :) Nice one, thanks for posting back to confirm the solution as it may help someone else in the future! 1 Quote Link to comment Share on other sites More sharing options...
