Sheppy84 Posted January 13, 2018 Share Posted January 13, 2018 Hi there. Long time viewer first time poster. Come across an issue when changing my alternator. I can't figure out how to release the tension to get the belt all back on and tight. I've googled it and tried various things but just can't figure it out. I've attached a pic of the bit I think I should be using. It's a ford focus 2.0 diesal 2005. Quote Link to comment Share on other sites More sharing options...
Mattysw Posted January 13, 2018 Share Posted January 13, 2018 Hi mate. I changed my alternator this morning, i loosened the small pulley just to the right and up from the aircon unit ( bottom right) as you look into wheel arch. Hope this helps Quote Link to comment Share on other sites More sharing options...
Sheppy84 Posted January 13, 2018 Author Share Posted January 13, 2018 6 minutes ago, Mattysw said: Hi mate. I changed my alternator this morning, i loosened the small pulley just to the right and up from the aircon unit ( bottom right) as you look into wheel arch. Hope this helps The nut inside the wheel? Quote Link to comment Share on other sites More sharing options...
Mattysw Posted January 13, 2018 Share Posted January 13, 2018 Yeah, itll go pretty loose before coming off, should be enough to get belt back over Quote Link to comment Share on other sites More sharing options...
Sheppy84 Posted January 13, 2018 Author Share Posted January 13, 2018 So the nut in the small wheel? Anti or clockwise? Quote Link to comment Share on other sites More sharing options...
Mattysw Posted January 13, 2018 Share Posted January 13, 2018 Anticlockwise, thats how i did it. But others may know another way, but i found it quick that way. Quote Link to comment Share on other sites More sharing options...
Sheppy84 Posted January 13, 2018 Author Share Posted January 13, 2018 Got it. Thank you. Had to take it off as couldn't do it on the car. Bolted back on and released and jobs a good'un Thanks mate 👍👍 Quote Link to comment Share on other sites More sharing options...
Mattysw Posted January 14, 2018 Share Posted January 14, 2018 17 hours ago, Sheppy84 said: Got it. Thank you. Had to take it off as couldn't do it on the car. Bolted back on and released and jobs a good'un Thanks mate 👍👍 No probs, glad i could help 👍👍 Quote Link to comment Share on other sites More sharing options...
