Sign in to follow this
Focus ST 1980
Dashcam earth point?
I have a 2006 Focus ST.
I was bought a NextBase dashcam for Christmas, however as it's an ST I don't really want an unsightly 12V power plug powering the dashcam.
I bought the NextBase hard wire kit which piggy backs off a fuse in the fuse box. I went to install it today but can't work out where to ground the kit, it's got to be close to the fuse box under the glove compartment as the hardwire kit positive and earth wires are not that long.
Does anyone know where the best place to ground is in the passenger footwell on a 2006 ST?
Thanks in advance
I have grounded some of my stuff to the fuse box bracket, but obviously can be a little bit of a pain potentially for anyone changing the pollen filter!
Changing the pollen filter is a massive pain anyway.  I've changed heater matrixes in other cars with less annoyance.
So did you use one of the two securing bolts of the bracket?
I did think to try that but its painted black and the bolts washer the other side is plastic, where on the bracket?
 I've just done this earlier today.  If you peel away the door trim and then remove the dash end panel, that will expose a useful earth bolt. You might have to extend the wire as you say it's a bit short.
Thanks,  I started peeling away the rubber strip running along the door frame and sill then yanked up the plastic panel next to the ST door sill logo and found two earth points.
I chose the back windscreen wiper fuse for the camera.
I believe it's sandwiched between the front of the bolt and the bracket (so only contact between the back of the bolt head).
Hey guys, so I too am hardwiring dash cam to fuse box and can't find a suitable earth point. I removed the door seal and can see some bolts however I can't find an easy way to remove the plastic housing. I've got a 64plate focus navigator. Any help would be greatly appreciated.
Just now, davecantshoot said:
Only possible point I can see is this. Would it be suitable
Should be. If the camera powers up and shows it's charging then it will be ok.
Thanks, before I try that is there an quick and easy way of dropping the glove compartment. I could probably get to something there.
The side panel with the airbag sticker just pulls off.  Mine is there with the blue crimp.
It might not be such a good contact with the black painted part in your photo.
can someone tell me which fuse can I use to piggyback for hard wiring dashcam from fuse box?
also what fuse amp is ideal?
yunii
1 hour ago, yunii said:
 Can someone tell me which fuse can I use to piggyback for hard wiring dashcam from fuse box?
yunii
Fuse F100 on the mk2.5 focus comes on with the ignition, the amperage should be determined by the existing plug I used a 10 amp red fuse.
That's where mine is plugged in Guide: https://www.fordownersclub.com/forums/topic/65147-guide-fitting-dual-camera-dvr-system-focus-mk2-mk25/
I've also earthed on a bolt above the glove box where there was already another item earthed it may have been the bluetooth module earth point.
on the focus I wired direct to back of 12v power outlet below radio.
yunii
btw the dashcam is nextbase with parking mode so switches off when not in use.
  Only 75 emoji are allowed.
