Kapper Posted January 30, 2018 Share Posted January 30, 2018 Noticed a pretty loud clunking noise from the clutch / trans other night, can be heard in the video: Noise goes away with the clutch down but comes back while clutch is engaged in neutral. I've looked around for info on worn release bearings and input shaft bearings but the noise doesn't sound like any symptoms described for them. Would appreciate any input, Cheers :) Quote Link to comment Share on other sites More sharing options...
Martin-Fiesta-MK6-1.4 Posted January 30, 2018 Share Posted January 30, 2018 aslong as the car is driving ok then i wouldnt worry too much about it just yet, new clutch will probably be needed in 6 months to a year 1 Quote Link to comment Share on other sites More sharing options...
Kapper Posted January 30, 2018 Author Share Posted January 30, 2018 Alright thanks for the advice Quote Link to comment Share on other sites More sharing options...
isetta Posted January 30, 2018 Share Posted January 30, 2018 what engine is this, could we be talking about a DMF (dual mass flywheel) which are well known for wearing and being noisy when your foot is not on the clutch (and creating loads of iron filings which gets attracted to the magnetism of the stater motor and then causes starter motor problems). I think only diesels have a DMF and then not neccessarily all diesels. Quote Link to comment Share on other sites More sharing options...
zain611 Posted January 30, 2018 Share Posted January 30, 2018 50 minutes ago, isetta said: what engine is this, could we be talking about a DMF (dual mass flywheel) which are well known for wearing and being noisy when your foot is not on the clutch (and creating loads of iron filings which gets attracted to the magnetism of the stater motor and then causes starter motor problems). I think only diesels have a DMF and then not neccessarily all diesels. Doesn't the mk6 fiesta 1.6 and 1.4 diesels have a single mass flywheel? I thought this was done as I heard the older fords had stalling problems with the dual mass flywheel Quote Link to comment Share on other sites More sharing options...
Lewisford Posted January 30, 2018 Share Posted January 30, 2018 I have the same problem I’m changing my clutch tomorrow and if it sorts it I’ll re-post 2 Quote Link to comment Share on other sites More sharing options...
Kapper Posted January 31, 2018 Author Share Posted January 31, 2018 It's the 1.25 so defo no DMF haha. I bought it about a month ago and the previous owner said he had a clutch replacement (even provided a receipt) not sure of the date but said it was recent, will have to check. Pretty sure it was just the clutch though, no clutch kit. Good luck Lewisford Quote Link to comment Share on other sites More sharing options...
isetta Posted January 31, 2018 Share Posted January 31, 2018 well if the work has just been done perhaps someone forgot to do something up tight properly. It is not rare to find that work that has just been done on a car leads to more because it is sometimes a problem that was misdiagnosed and the work done did nothing to sort out the real problem whatever that might be, or the work was done badly. Years ago my sister bought a Metro, after a few months the clutch started vibrating badly and then suddenly disaster occurred in the clutch. Dismantling showed that someone had not done something up tight properly and it ruined the end of the crankshaft where the clutch was, so the car was scrapped as uneconomic to fix. Quote Link to comment Share on other sites More sharing options...
Kapper Posted January 31, 2018 Author Share Posted January 31, 2018 Just checked the receipt, had a clutch kit put in November! I bought the car at the end of December (it didn't have this issue until now). Think it's worth contacting the business that did it and seeing if they'll check it over? I'd assume they're liable even though I didn't own the car when the work was done Quote Link to comment Share on other sites More sharing options...
james_60 Posted February 3, 2018 Share Posted February 3, 2018 If the clutch was recently replaced. then theres your dinner. It shoudnt rattle like that. Something has been mis aligned Jamie Quote Link to comment Share on other sites More sharing options...
