MK2 head lights flash
jrn1919
Hi  started to notice that my headlights flash in the morning when I start up
never done this before ,flash as in 1 flash and then it starts
Any ideas?
Read it could be the battery or alternator
MK2 2008 1.8 petrol
Thank you
Mines done that and found it was the original factory battery still installed and garage said it needed replaced. I would check you battery and see if it says ford on it and get it tested.
  • Like 2
yes was planning on the easy option first ,hope it is this was just seeing if others had the issue ,thanks for your reply
battery is on its way out, I have heard it’s a ‘visual’ signal
changed battery today so see what happens , it still had the original on that was almost 10 year old :ohmy:
Yep long lasting ones I was shocked myself. You are lucky you noticed the signs now as it gets worse.
