Azz899 Posted February 12, 2018 Share Posted February 12, 2018 Does anyone know if the zetec S led style lights are plug and play to a normal zetec? i have a zetec with all the ST kit (put on by the previous owner) but the standard rear lights look abit gash sp was hoping for an easy upgrade Cheers Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted February 12, 2018 Share Posted February 12, 2018 Do you just mean the rear clusters? Ie not the high level brake light? Not sure if the same as on my titanium, (that has the led tail light bars) but the fogs and brake lights have been swapped. Brake lights are now single filament 382's and the fog lights are twin filament 380's which only use the 21w filament! If the looms match, they should be plug and play, they just moved the bulb holders around... If anyone wants a set of red 382 LEDs for £7 posted let me know! They are cheapy (though solid and work fine) eBay ones which interfered with my DAB, but I ended up with a spare unopened set anyway. Edit:: just noticed you put mk3.5. Not sure if this still applies. Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 13, 2018 Author Share Posted February 13, 2018 Yeah just the rear clusters, i have a mk3 outside aswell i may have a look at the wiring (this has the led bars aswell) hopefully it wont have changed much between the 3 and 3.5 Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted February 15, 2018 Share Posted February 15, 2018 I think they are fairly plug and play, but you do need to tell the car you have LED tail lights, which will also require the LED running lights on the front as AFAIK the computer will turn off the front sidelights and/or throw an error about faulty lights. I might be wrong however. Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 15, 2018 Author Share Posted February 15, 2018 ive got an ELM cable on the way as ive bought a cruise control steering wheel (something i miss about my MK3) i may buy the rear clusters anyway and then see how i get on worst comes to worst im "forced" to upgrade the front lights to DRL's that would be a shame like :) Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 15, 2018 Share Posted February 15, 2018 2 hours ago, Azz899 said: ive got an ELM cable on the way as ive bought a cruise control steering wheel (something i miss about my MK3) i may buy the rear clusters anyway and then see how i get on worst comes to worst im "forced" to upgrade the front lights to DRL's that would be a shame like :) Will you be using Forscan? If so, is there a list of coding available for various mods, eg locking while in motion etc Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 15, 2018 Author Share Posted February 15, 2018 I think its focccus but ill be getting both bits of software and seeing which ones better, any suggestions? Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted February 16, 2018 Share Posted February 16, 2018 11 hours ago, Azz899 said: I think its focccus but ill be getting both bits of software and seeing which ones better, any suggestions? Focccus and ELMConfig don't work with most of the MK3.5's at present. I think Forscan is your only option atm. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted February 16, 2018 Share Posted February 16, 2018 1 hour ago, DJ_Andy_M said: Focccus and ELMConfig don't work with most of the MK3.5's at present. I think Forscan is your only option atm. Focccus should work now. It didn't when the MK3.5 first came out, but they've updated it since. 2 Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 16, 2018 Author Share Posted February 16, 2018 Hopefully one will work, im sure ive seen someone using focccus on a mk3.5 on a post somewhere Quote Link to comment Share on other sites More sharing options...
TDCiST Posted February 16, 2018 Share Posted February 16, 2018 You may need Forscan too... that’s a great bit of software! And has a dedicated forum too you can change a hell of a lot in forscan Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 16, 2018 Author Share Posted February 16, 2018 yeah i had vagcom in my last seat leon so having these bits of software is a must for your own car Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 17, 2018 Share Posted February 17, 2018 20 hours ago, alexp999 said: Focccus should work now. It didn't when the MK3.5 first came out, but they've updated it since. The FoCCCus program was never updated for the Focus MK3.5. When Ford released the Focus MK3.5 the original developer of the FoCCCus program stopped developing the program. The original developer had no intentions to update the program for the Focus MK3.5. Version 0.8.5 is the latest version that was released by the original developer. Some other persons wanted to update the program for the Focus MK3.5. They got the approval of the original developer and developed Version 0.8.6. This version has limited support for the early Focus MK3.5. However after a short period Ford changed the hardware numbers of the MK3.5 IPC and BCM. These vehicles are not supported by the FoCCCus program. The Forscan program or the Ford IDS diagnostic system are much more suitible for the Focus MK3.5. 3 Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 17, 2018 Author Share Posted February 17, 2018 Assuming i dont need a special elm cable for forscan? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 17, 2018 Share Posted February 17, 2018 The Central Car Configuration of the Focus MK3/MK3.5 is stored in both the BCM (Body Control Module) and the IPC (Instrument Cluster). The main CCC file is stored in the BCM and the backup CCC file is stored in the IPC. The BCM is connected to the HS (High Speed) CANbus network and can be diagnosed using a standard ELM327 interface. The IPC is connected to the MS (Mid Speed) CANbus network and can not be diagnosed using a standard ELM327 interface. This can only be done with a modified ELM327 interface which has a switch to switch between the HS CANbus and the MS CANbus network. Because the IPC only contains the backup CCC file and not the main CCC file it is not really needed to change this file. The system uses the main CCC file to configure all modules and settings. Keeping the backup file original will not affect any of the changes made in the main CCC file. However I personally prefer to have both the main and backup CCC file to be identical. Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 21, 2018 Share Posted February 21, 2018 I don’t seem to have been notified of all the updates to this post, thank you for all the responses re Forscan. Your last post has me a little confused Wilco, it’s gone right over my head lol. I was told you are the man to speak to regarding Forscan updates, I’ve got a few questions regarding retrofitting a rear view camera and a few other mods I’d like to do. Where is the best place to pick your brains, is it best to PM you? TIA Quote Link to comment Share on other sites More sharing options...
haygun Posted February 21, 2018 Share Posted February 21, 2018 my old car, LED rear lights change review: https://www.drive2.ru/l/10018203/ Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 21, 2018 Author Share Posted February 21, 2018 13 minutes ago, haygun said: my old car, LED rear lights change review: https://www.drive2.ru/l/10018203/ plug and play or did you require wiring? cheers Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 22, 2018 Author Share Posted February 22, 2018 Just to close this out, the rear lights with the "LED" strip are plug and play. Went out on a whim and bought them today 1 Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted February 23, 2018 Share Posted February 23, 2018 16 hours ago, Azz899 said: Just to close this out, the rear lights with the "LED" strip are plug and play. Went out on a whim and bought them today Do you get just the LED lit up or the bulb too? Quote Link to comment Share on other sites More sharing options...
Azz899 Posted February 23, 2018 Author Share Posted February 23, 2018 On sidelights just the LED strip and the top bit becomes your brake light Quote Link to comment Share on other sites More sharing options...
