Fiesta Mk6.5 Starting Problem (Video Included)
Hi Guys,
I've got a problem with my 2006 Fiesta Mk6.5 1.25
This started off as a very rare occurrence but it's got much more common now,  to the point where I've had to bump start it about 5 times this week!
I've recorded a video of what the car is doing. Apologies for the dark video:
Is it my starter motor not engaging properly??
I've changed the battery this week as this was the car's original battery and I thought that maybe it wasn't delivering enough current. Unfortunately this didn't solve the problem.
Any help or advice would be gratefully received.
Cheers,
Lund243
I don't think that's the battery. Do you have a diagnostic tool to check for any errors?
Starter solenoid not engaging.  Can be caused by a low battery but in this case its going to be the solenoid itself. Can be bought separately from the starter but it's easier to change the whole thing.
No I don't unfortunately
Ok thanks for the info! I'm going to try to remove the starter motor this morning. Is this an easy job?
Honestly I haven't changed one on a 1.25 Fiesta - it's on the front of the engine/gearbox so should be easy to remove from above but not sure how tight the access is.
Looks like I have to come from underneath. From what I can see there's 3 bolts which I've undone but it won't separate easily. Plus I'm having trouble removing the connector! I'm worried I might break something 🙈15188643672041110911063.thumb.jpg.f7cc7422f2071579256190bee471cef8.jpg
Ah, access is tight there then...  Damn Fiestas with their small engine bays lol.
Yeah it'll just be 3 large bolts holding it in.  Might be a metal dowel or bit of corrosion holding it to the gearbox so give it a tap and wiggle to free it off if its stuck.  You will need to remove wiring as well though, on the other end of the starter there's a thick cable held on with probably a 13mm nut.  The battery MUST be disconnected before you go near that thick cable just in case it isn't already.
