Brake Discs
So I'm needing new break discs & pads and I'm going to order the parts myself but I'm not sure which discs I'm supposed to get because 2 options come up on Euro Car Parts.
1st Option:
Brake Disc Thickness [mm]20
Brake Disc TypeVented
Centering Diameter [mm]63,5
Diameter [mm]239,5
HasWarranty0
Height [mm]43
Hole Arrangement / Number04/04
Minimum Thickness [mm]18
Pitch Circle Ø [mm]108
Weight [kg]3,9
Fitting Position Front
Fitted Quantity 2
Other Information Without ABS
2nd Option:
Brake Disc Thickness [mm]22
Diameter [mm]258
HasWarranty0
Height [mm]43,5
Minimum Thickness [mm]20
Weight [kg]5,14
Fitted Quantity 2
Other Information With ABS
Thanks in advance for any help.
the first has a smaller diameter than the second. you could measure the diameter of those on the car. you must get the same so it aligns with your caliper. first says without ABS, 2nd says with ABS. do you have ABS?  I think it was compulsory on new cars by 2007.
as isetta says check the diameter of the current discs and the same diameter.
