kiehugh Posted February 24, 2018 Share Posted February 24, 2018 Afternoon all, The cigarette lighter on my MK2 is not working. I have seen few threads that say if the radio is working then it is not the fuse. I am pretty rubbish with cars so could do with some guidance. Quote Link to comment Share on other sites More sharing options...
F0CUE Posted February 24, 2018 Share Posted February 24, 2018 They are defo separate fuses I would test the fuse first. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 24, 2018 Share Posted February 24, 2018 Check fuse 39 under the glovebox.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Botus Posted February 25, 2018 Share Posted February 25, 2018 I'd read some how you can configure from always live 12v, to ignition switched live, by playing with the fuse position.... but then couldn't find out if correct or what positions you need... as is, always live is a ***** idea Quote Link to comment Share on other sites More sharing options...
Micro Posted February 25, 2018 Share Posted February 25, 2018 9 minutes ago, Botus said: I'd read some how you can configure from always live 12v, to ignition switched live, by playing with the fuse position.... but then couldn't find out if correct or what positions you need... as is, always live is a ***** idea Heard it, don't see how it is possible from the wiring diagram. Either use a fuse tap and run a new live wire, or a relay. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 25, 2018 Share Posted February 25, 2018 I believe the mk3 Mondeo had the option of swapping from permanent to switched but definitely not heard of it on any Focus model.A new feed from a switched circuit and a fusetap is the only option.Sent from my SM-G930F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
