Strange Onetouch
Got a strange one touch window issue
Originally only had front electric windows, passenger worked fine, drivers would onetouch open but not onetouch close
Have now added rear electric windows and now all passenger windows onetouch works fine, drivers window now works fine but drivers side rear window will onetouch open but won't onetouch close
Anyone have any ideas? Strange how the problem has moved from front to back after fitting rear windows although positive side is at least it works on my window now lol
Does drivers side rear ‘one touch’ close?
It will one touch open but won't one touch close
Sorry I meant the passenger rear, my bad. I can’t remember my Mondeo having ‘one touch’ in the rear, it’s often only the front.
Yeh one touch on rear passenger
The wiring looms in the door the parts are actually called one touch
Have you tried just disconnecting the battery for a few minutes and seeing if that will just reset things? Other than that I’m afraid I’ve no clue ☹️
What model/year did you get the one touch rear looms from?  Do you have a part number?  Thanks.
I take it you've tried the suggestions/ common solution in this sticky post.
It's working!
Tried the reset procedure again and now it's working!
Thanks for the input all
