Shiv_P Posted February 26, 2018 Share Posted February 26, 2018 Hi all I posted in the general chat but was advised to post here In a few months I might be looking at buying a mk4 mondeo TX for around £5-5.5k to commute to and from uni (around 30 miles per day), 80ish percent motorway. I only will be 19 but I will have to fend off the older man vibes :) A few questions - from what year did bluetooth streaming become standard on titanium X or was this always the case? And with the screen between the dials, does this replace a sat nav or is the sat nav an option? As I can't see many cars with the sat nav. 2.0 petrol - is this generally reliable or am I better off going for the 2.0 or 2.2 TDCI? For the mileage I will be doing I'd rather have a petrol to avoid DPF issues etc What sort of MPG can I expect from the 2.0 petrol? Looking at the manuals only Thanks Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted February 27, 2018 Share Posted February 27, 2018 Not sure on the bluetooth streaming query, it depends which bluetooth module is fitted. The screen between the dials (Converse+) isn't a replacement for a factory sat nav, if fitted it replaces the more standard head unit. Even though the TDCi's of that generation have the newer more durable cDPF (I believe) I'd expect if it's regularly only been used to do 30 miles a day that it wouldn't be long before you'd start having DPF issues. 2.0 Duratec engine is chain driven so as long as the oil has been done each year you shouldn't have to worry about having the cambelt done, generally it's a pretty solid engine, I wouldn't expect much more than 35 MPG going on the journey type you described. Maybe slightly more in the summer months due to the engine getting up to temp quicker. Quote Link to comment Share on other sites More sharing options...
al2052 Posted February 27, 2018 Share Posted February 27, 2018 (edited) Edited February 27, 2018 by al2052 removed Quote Link to comment Share on other sites More sharing options...
Shiv_P Posted March 3, 2018 Author Share Posted March 3, 2018 Thanks for the reply Are the cooled seats standard on the Titanium X or were they just a cheap option? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted March 3, 2018 Share Posted March 3, 2018 1 hour ago, Shiv_P said: Thanks for the reply Are the cooled seats standard on the Titanium X or were they just a cheap option? They where not standard and certainly not a cheap option Quote Link to comment Share on other sites More sharing options...
