fiesta 1.0 ecoboost
Hi had a problem with front and rear screens not working checked fuses ok so changed r2 relay Started car no luck but after a couple of mins and pressing the front screen switch it came on same thing with rear so I thought all ok But when I went back after a couple of hours same problem but after 2 to 3 mins  and pressing the switch a couple of times and reving the car started working again press the switches off and then back on they work fine turned ignition of then back on works fine any ideas why after leaving for a couple of hours they don't come on straight away
Could be a near flat battery. The ecoboost has a battery saver so if the state of charge  gets too low it cuts off none essential items and concentrates on getting the battery charged as fast as safely possible. First thing I would do is hook it up to a battery charger and fully recharge it and see if it cures the problem.
