miff Posted March 7, 2018 Share Posted March 7, 2018 hi all looking for some help with airbag light streetka 2004 light flashes 5 times then goes solid checked connections under seats been searching for codes cant find a diffinitive answer but was thinking about getting a control module from scrapyard thing is i dont know the location of this on the car if anyone can help with codes or location or if the ford ka fits streetka would be much appreciated thank you Quote Link to comment Share on other sites More sharing options...
miff Posted March 8, 2018 Author Share Posted March 8, 2018 hi update after reading about codes i think the 5 flashes are in fact single flashes apparently its supposed to start a sequence theres a 2 second pause between each flash then goes solid been trying to work this sequence out but im stumped cheers Quote Link to comment Share on other sites More sharing options...
137699 Posted March 9, 2018 Share Posted March 9, 2018 Why don't you get the fault codes read? Instead of guessing at what might be wrong? Quote Link to comment Share on other sites More sharing options...
miff Posted March 9, 2018 Author Share Posted March 9, 2018 hi i cant drive car mot is out this is why im trying to find out if anyone had an idea going for mot saturday morning Quote Link to comment Share on other sites More sharing options...
andybadcats Posted March 9, 2018 Share Posted March 9, 2018 Remove steering wheel, unplug airbag wiring harness, spray switch cleaner inside plug, clean with cotton bud. Job done. Always disconnect the battery before working and Wear safety glasses. Quote Link to comment Share on other sites More sharing options...
