Water Leak
hi people am having problems with loosing coolant , its leaking from behind the engine , as you look at it from front of car it appears to be at rear of engine on the right and its dripping quite bad I topped up the water tonight to just above the min mark and in 30 mins there was nothing in water tank ! any suggestions would be gratefully received . Dave
The thermostat housing is a favourite if it is the plastic type. After a few years these warp. Pretty easy to change but do cost around £80.
thanks for the prompt reply , how difficult are these to replace ?
thanks again Dave
to follow on its the plastic thermosts housing below air filter how does air box come off to get at thermostat housing ?
post-26422-0-29959000-1412859213_thumb.j
