Streetka Rear Offside Indicator
Offside rear indicator has stopped working.
Front offside and side light are fine.
Fuse is fine.
Bulb is fine.
Everything on the nearside works fine.
Cant work it out?
check the wires have not corroded or broken.you can try removing the whole light from both sided and connect the working one to the non working one with out installing it. if it dont work then either corrosion of terminals or a broken wire unless you have a proper tester to test the wires thats what i would do
Cheers man. Wires n terminals appear fine so i think best bet is to get a tester to see if the wires are supplying the terminal with correct voltage
always handy to have a tester in the tool box. i would also try a diffrent bulb that you know works as sometimes even a new bulb maybe duff or try the bulb from the duff light in the good light if you get my meaning
Yep we eliminated the bulb as the problem.
Would the tester need to be an auto electrics specifically? And where would most cost effective place be to buy one (apart from online as i need to buy it in person today to get this sorted)
Cheers again
goto a pound shop to get one. it looks like a screwdriver but pointed with a wire cuming off it with a aligator clip on the end to earth it.
clip the alligator clip to an earth poing & press the pointed part into the wire or onto the connector block to check if there is power there. its a simple but effective too to have or you can go get a more advanced item with lcd display etc on it.
let us know how you get on and post the fix if you find it as will be handy for other people
