P060C Internal Control Module Main Processor Performance
Having on going issue with my Mk2 Foucs 1.6 2005 105k. I intermittently get a Power train light on the dash. I hooked up a module and the code P060C is coming up.
More impotently if i need to turn the car off then on again after a short while 2 seconds to about an hour, sometime the car fails to start, the immobileser LED flashes rapid while this is happening.
Does anyone have any ideas? should I try a ECU reset (battery disconnect)? I did once also get a system voltage under 14v warning but the battery seems ok with the correct voltage?
Any clues?
Read this with having a low battery warning there may be a battery issue http://www.obd-codes.com/p0
page not found. Would that be linked to the P060C? and the link doesnt work :(
