Clutch Release Bearing Squeak
Looking like a need this part which is £51 from ford parts uk website, any insight on how this is to be change, price of job is swaying towards 1.jpggearbox of/ gearbox not taken of, not to sure
The whom gearbox has to come out if its squeaking try wd40 on the rear of the clutch pedal
If you're changing a release bearing you're as well doing a whom clutch kit a garage will take around £309 minimum that's mainly labour
As I say if it ain't broke leave it alone
Mine squeaks on ocassion too,
Adds to the chu chu effect 🚂Don't you think?😀
Wouldn't know Lenny kids and the Mrs dont shut up long enough to find out lol
what type of squeek is it
is it the type your bed makes when uhh hmmm :ph34r::ph34r:
or the type that new trainers sometimes make on certain floors :rolleyes::rolleyes:
Jamie
Jamie
The type of squeak that the bed, cooker, kitchen table, and sofa makes😥
oh jeez heheh and i thought i was the naughty one in these here parts :ph34r::ph34r: :o :o :o
Nothing broke just very annoying,its only when moving of in 1st gear it happen, problies will happen if set of in 2nd or 3rd but what melon would do that.
Cant describle the squeak just ford said its release bearing.
would i need to access from under car or can i get to it inside footwell, not to sure if it will be more towards engine needs lubricating
The gearbox needs to be removed to access the release bearing.
Jamie
Jamie
cheers jamie, was quoted £290 for whole kit so after xmas is over and have some spare cash might just get full kit done and its out of was, £290 is worth getting shot of squeak
Please tell me that your not just having the release bearing etc changed
While its apart change the clutch
Jamie
Jamie
definatly not mite as well get kit and save on 2 labour charges....290 for kit and fitted so after xmas will be getting done
