Read Camber
Evening all, I started this in the main forum but thought I might try here,
I've lowered my max had it set up correctly using the hunter system all within there tolerances however n/s rear tyre has massive wear on inside and camber is more than other side.
What is causing this, can the camber be adjusted if so where do I adjust it?
Not paying £40 odd quid again to have it set up.
