Rear Anti-Roll Bar Links-Focus Mk2
Hello
I have a 2006 Focus TDCI Estate
I just got it back from the garage and they tell me the rear anti roll bar links are broken.
I have looked everywhere online and have looked under my car, all I can see is where the anti roll bar connects to the suspension on each side there are bushes that seem to be deteriorating.
But when I look for the parts online I seem to get two different kinds of links that I can buy, this makes me wonder if there is another spot on the anti-roll bar that has links that I can't see??
Can anyone help out? If you understand what I mean.
Pics of the parts are attached.
post-67317-0-53350700-1449063704_thumb.j
post-67317-0-22572100-1449063705_thumb.j
I recently had to replace mine, the MK2 can be fitted with 2 different lower arms, each arm type uses 1 but not the other type of anti-roll bar link.
If you can post a picture of your lower suspension arm we'll be able to advise which links you need.
Basically is your lower arm basically has a "kink" in it you need the ones in the 1st picture, if the arm is "straight" you want the 2nd ones.
Call your local Ford parts department with your registration number and they should be able to put you right buddy.
the one in the mk2 hatchback is the one on the left. im not sure about estates, as williamweb said best to ask Ford parts
