2005 Streetka luxury
HI all, I am going to view a Streetka tomorrow. It looks very nice, with an MOT and no adversaries.
What in particular should I watch out for and ask about?
Hi Mitchy,
Check for corrosion, good test-drive, listen the engine, misfire is quite common. Also check:
- heater can produce cold and hot air
- the aircon is working. Don't buy the "just need re-gasing " talk, if it isn't working, usually compressor gone
- listen the belt, it shouldn't make any noise
- rear window. If it is blurry, not good. Quite expensive to change
- check the level of the coolant in the car, also no excessive white mist from exhaust
- look for leaks, check the carpet it is wet or not, no mold
- check the heated seats are working properly
- check the power steering, it should be smooth and not crunchy - noise
Good luck, let us know how was it
