Ford Focus Wipers
I've recently purchased a 66 plate Ford Focus and have noticed that my front wipes appear to be wobbling from the middle to the bottom of both wipers when moving across the screen. Is this normal with these wipers?
Normal.
As they are aero blades rather than the older sprung type they do tend to be a bit floppy.
You may be getting a bit of drag from dirt or greasy deposits though, try cleaning the rubber edge with vinegar (or vinegar based window cleaner spray/wipes).
I uses a 50/50 mix of water and white vinegar works a treat on all of you glass
Yep, same over here. I have it on my focus, and it was also happening on the rental Focus I had while mine was being fixed.
