Focus MK1 1.6 - Stuttering
My Focus MK1 1.6 Petrol has a problem, only started today
It is very low on power and stutters like mad
I've checked and cleaned the spark plugs and leads
made sure the air filter etc was ok
Any ideas please, as I need it for work tonight
Try new spark plugs first then next step leads .see if it eliminates the fault.
Yunii
Sent from my SM-G925F using Tapatalk
fuel starvation? fuel filter blocked?
Turned out to be the most common problem with MK1's
The coil pack
Thanks everyone
You were lucky. Coil pack failure on my mk1 killed the ecu. I had to spend £400 on a new resistor...
And I even had to have a second brand new coil pack fitted or the place the garage sent the ecu to wouldn't guarantee it...
Glad you got it sorted.
