Preload wastegate 1.6TDCI
Hello
I have a focus 1.6TDCI, I have a turbo issue.
When driving i notice my boost Pressure (20psi) drops to 10-12psi if i reach 3,500 RPM maybe a coincidence as it is normally uphill i reach 3,500 RPM but has happened a few times on the flat.
I also have a turbo underboost issue (no EML) Forscan shows code, But occasionally more so uphill my turbo will pretty much cut out, There will still be pressure but not noticeable.
So far i have done.
Cleaned DPF
Replaced all sensors on DPF and intake air temperature sensor.
Checked all turbo pipes for leaks (removed and inspected)
Cleaned MAP sensor.
Is there anything else i can try?
On another note i have read about preloading the wastegate and wondered if anyone had done this, I was thinking of doing it to counter the under boost? But im worried about any damage it might cause.
Thanks in advance
