oil cooler
can anyone explain why this is described as an oil cooler when it's attached to the block out of the airflow with the hot water from the heater flowing through it
http://www.ebay.co.uk/itm/BRAND-NEW-FORD-FOCUS-OIL-COOLER-1-8-DIESEL-1999-2005-DIESEL/251306680011?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
i think I am right but don't gurantee it. i think the pipes with the blue caps on connect to water hoses to help cool the oil because the water temperture will normally be below the oil temperature
thanks for the reply isetta, I've just checked the normal engine oil and water temps and you're spot on
there have been cases of these leaking inside so that the oil and water mix
