Mondeo Mk4 Tcdi 2007>
Hi Everyone.
My Mk4 Mondeo had been showing an ABS light. I took it to KwikFit for diagnostics and it showed as n/s/r sensor fault.
Once replaced the light stayed on so they suggested changing the hub/bearing.
Again once changed and road tested the light stayed on and the diagnostic would not re-set the light.
Im really stuck (and so were they) as to what the problem could be.
Any advise would be priceless please.
Thank you in advance
Adrian
i would not trust kwick fit for anything, try another garage for a fault check as ot may not be the right sensor that you replaced, it could also be a wireing fault check that the voltage is the same at all the sensors.
Hi
Thank you
Ade
