Does A New Pump Need New Injectors
As above iv got to put a new diesel pump on my Mondeo tdci well a second hand one so can I use my injectors or do I have to use the injectors from where the pump come from
Unless your concerned about the injectors at present there shouldnt be any need for replacing them, should just be the pump.
Also is there Any way of testing a second hand pump to see if it works ok and how much does it cost to have the new pump programmed
Never really thought of programming a pump, never knew it needed doing! as for testing a pump, if its on a motor at a scrappy, just take an injector out and get someone to start the motor, if fuel leaks out then its working!
