Wishbone Bushes
I recently took my ka for its mot at halfords, when i got it back it came with an mot advice list which said i need to replace the 'front lower arm bushes'. Is this the bushes that join the lower wishbone suspension to the subframe? Can i buy these on there own or is is it best to replace the lower wishbone arm at the same time?
I would be greatful if someone could help me.
you can replace these bushes but you might be just as cheap/easy to replace the full wishbone which will also have a new ball joint
try here
i use them all the time & quick postage
www.buypartsby.com
if ur not sure on the part then phone them with the reg of car & they will sort the parts for you
i recall it was £25.00 each complet arm with bushes and ball joint thats inc vat
about £57.00 for a pair inc postage
if your going for a genuine ford part that will be £95.00 each side
