Radio Code Wanted
Hi there I would be grateful for any help on this, just brought a focus had some work done which involved removing the battery, now I need a code, when I press 1 +6 I get DP MV SH 50700012 07-02-00
Cant get to the S/N wondered if that number above was anything to do with getting my code?
Jason
You may have to extract the radio to find the V or M serial number , but no codes are given out on this Forum
That's not the code had the same problem only way is out mate
OK, well thanks for the heads up anyway.
If your unable to remove the radio the easiest way I found to read the sticker which is mounted on the top of the radio is to remove one or both of the centre blowers (they just pull out).
