05 Zetec Door Speakers
Anyone know what size the door speakers are for a 05 Zetec 3 Door
also how to get the door panel off
Cheers
mk3/4/5 speaker size-13cm/5.25in
mk6 speaker size 6x9
it would be best to look at a haynes for the removal as there are a few hidden screws or try a internet search
I've read on another forum that they are 5 x 7 to fit 6 x 9's in you have to cut the door
Is this true?
Is this true?
i'll look in the books at work to see if it needs any adapters, and then it should tell me what size it realy needs
double checked the guide and your right they are 5x7 must of had a senior moment
6X8's fit so i'm told just got a set of Kicker DS680 gonna put them in when i get home from work
Sounds good mate, might be handy to put some pics up to help others.
Just fitted a set of 6x8's went straight in no problem
Only thing is there not that bassy i think i may of wired them wrong does anyone know which wire is which there is a Grey & White wire
Will upload pics if i need to swap the wires around
  • 2 years later...
Hi does anyone know if all the speakers (front and rear) in 3 door mk6 fiesta are the same??
and would these fit ... http://caraudiosecurity.com/shop/product/products_id/9147.html ... any help would be much appreciated
